Redating from file name
AlainB
Post by AlainB »
Some pictures have no date set in the metadata, but the date is encoded in the file name (for example IMG-20210811.jpg)
With the command line exiftool one can set the datetimeoriginal from the file name
exiftool "-datetimeoriginal<filename" IMG-20??????.*jpg
will set the date of all files selected by the pattern IMG-20??????.*jpg
Is is possible to do something similar from Photo Supreme, like redating (using the file name) all selected files ?
Re: Redating from file name
Why not call EXIF from within PSU with the required command line ?
This will then pass all the file names and the defined command to EXIF as an external application, once EXIF has finished then you can re-sync the images selected within PSU. I have the default(-k) set up but it can be changed as needed;
This could help?
viewtopic.php?t=27839
AlainB
Post by AlainB »
G8DHE wrote: 13 Feb 24 17:13 Why not call EXIF from within PSU with the required command line ?
Thank you for the suggestion, I have to find how to add exiftool ( a perl script) to the PtotoSupreme external applications (I am using a MacBookPro) and how to pass arguments from PhotoSupreme.
AlainB wrote: 16 Feb 24 10:26 I have to find how to add exiftool ( a perl script) to the PtotoSupreme external applications
Why not use exiftool outside PSU? I didn't know any reason why such a tool should necessarily be started from PSU
Post by snowman1 »
Hert wrote: 14 Feb 24 7:41 This could help?
And also this one: viewtopic.php?t=29314
AlainB
Post by AlainB »
RobiWan wrote: 16 Feb 24 18:49
IMHO It would be more straightforward to call exiftool from PSU:
- select pictures in PSU
- call exiftool
- convert to XMP
If you call exiftool from the shell, how will you tell PSU to "convert to XMP" the metadata in the files you just updated (and only those) ?
AlainB wrote: 17 Feb 24 20:21 If you call exiftool from the shell, how will you tell PSU to "convert to XMP" the metadata in the files you just updated (and only those) ?
I never do it like that. First I create a list of the files I want to change. I always call ExifTool from a shell, change the data I want and at the end in PSU "read Metadata from File". This makes all what I want and need.
AlainB
Post by AlainB »
If I were to use the shell, I would write a shell script that goes through all files with a given pattern (using the "find" command) , check if the date timeoriginal is set and if not set it according to the file name.
AlainB
Post by AlainB »
My computer is a MacBookPro and there is unfortunately no executable version of exiftool for OSX, only a command line version. The executable version exists only for Windows.
AlainB wrote: 26 Feb 24 17:36 only a command line version.
ExifTool is always command line tool.
AlainB
Post by AlainB »
According to "ExifTool by Phil Harvey" webpage
ExifTool is a platform-independent Perl library plus a command-line application
ExifTool is also available as a stand-alone Windows executableThe stand-alone Windows executable does not require Perl. Just download and un-zip the archive then double-click on "exiftool(-k).exe" to read the application documentation, drag-and-drop files and folders to view meta information
I'm sorry it make no sense
"The MacOS package installs the ExifTool command-line application and libraries in /usr/local/bin. After installing, type "exiftool" in a Terminal window to run exiftool and read the application documentation."
I was very long time Mac user.
AlainB
Post by AlainB »
If always means "always with MacOS" you are right, ExifTool is always (a) command line tool.
G8DHE suggestion was for Window.
AlainB wrote: 28 Feb 24 13:43 G8DHE suggestion was for Window.
No, his suggestion was OS Independent. You can put in this menu each App is OS executable.
