Hello forum:
I have some photos and videos with metadata field DateTimeOriginal = empty. I`d like to set it to the actual photo/video date. For some of the files, I`d like to set it to the date in the "Description Date" metadata field. For other files, I`d like to set it to the date in the filename (eg "PHOTO-2018-06-16-10-34-51.jpg"). I see this may be suitable for the Scripter tool, but I cannot program Pascal. Do you know of some good resource where I may get some redate Photo Supreme scripts to get me started?
thanks!
Fabris
Redating from date in filename
Re: Redating
Here's a script that redates based on file name. The requirement is that the file name is constructed with dashes (looks like yours is also). Here's some samples that can be handled:
Use the script at your own risk (always try it on a few copied files first) and feel free to customize it to your needs.
function DateStringToDateTime(ADateString: WideString): TDateTime;
var
ATokens: TTntStringList;
ys, ms, ds, hs, ns, ss, msecs: WideString;
y, m, d, h, n, s, msec: Word;
begin
result := 0.0;
ys := ''; ms := ''; ds := ''; hs := ''; ns := ''; ss := ''; msecs := '';
y := 1899; m := 1; d := 1; h := 0; n := 0; s := 0; msec := 0;
ATokens := TTntStringList.Create;
try
Tokenize(ADateString, '-', ATokens);
if ATokens.Count >= 1 then
begin
ys := ATokens.Strings[0];
if not IsValidIntNumberString(ys, False) then
exit;
if Length(ys) = 2 then
begin
if StrToInt(ys) < 20 then
ys := '20' + ys
else
ys := '19' + ys;
end;
y := StrToInt(ys);
end;
if ATokens.Count >= 2 then
begin
ms := ATokens.Strings[1];
if not IsValidIntNumberString(ms, False) then
exit;
m := StrToInt(ms);
if (m < 1) or (m > 12) then
exit;
end;
if ATokens.Count >= 3 then
begin
ds := ATokens.Strings[2];
if not IsValidIntNumberString(ds, False) then
exit;
d := StrToInt(ds);
if (d < 1) or (d > DaysInMonth(m)) then
exit;
end;
if ATokens.Count >= 4 then
begin
hs := ATokens.Strings[3];
if not IsValidIntNumberString(hs, False) then
exit;
h := StrToInt(hs);
if (h < 0) or (h > 24) then
exit;
end;
if ATokens.Count >= 5 then
begin
ns := ATokens.Strings[4];
if not IsValidIntNumberString(ns, False) then
exit;
n := StrToInt(ns);
if (n < 0) or (n > 59) then
exit;
end;
if ATokens.Count >= 6 then
begin
ss := ATokens.Strings[5];
if not IsValidIntNumberString(ss, False) then
exit;
s := StrToInt(ss);
if (s < 0) or (s > 59) then
exit;
end;
result := EncodeDateTime(y, m, d, h, n, s, msec);
finally
ATokens.Free;
end;
end;
function ExtractDateString(AFileName: WideString): WideString;
var
AFile: WideString;
APos: Integer;
begin
result := '';
try
AFile := WideExtractFileName(AFileName);
APos := WideTextPos('.', AFile);
if APos > 0 then
AFile := LeftStr(AFile, APos - 1);
Tokenize(AFile, ' ', ATokens);
result := ATokens.Strings[0];
begin
if WideTextPos('-', ATokens.Strings[1]) > 0 then
result := result + '-' + ATokens.Strings[1];
end;
finally
ATokens.Free;
end;
end;
procedure RedateImage(AImage: TImageItem; ADt: TDateTime);
var
ACatItem: TCatalogItem;
AXMP: TXMP;
begin
AXMP := TXMP.Create(False);
try
if PublicCatalog.FindImageCombined(AImage, ACatItem,True, vptNone) then
begin
PublicCatalog.LoadXMPForItem(ACatItem, AXMP, PublicOptions.CachedXMP);
AImage.WriteExifDateTime (ADt, [dteBase, dteOriginal, dteDigitized], TimeZoneOffset, False, AXMP);
PublicCatalog._SaveXMPForItem(ACatItem, AXMP, PublicOptions.CachedXMP, False, True, True);
end;
finally
AXMP.Free;
ACatItem.Free;
end;
end;
procedure HandleImage(AImage: TImageItem);
var
ADateString: WideString;
ADt: TDateTime;
begin
examples;
A. find first part up to space
B. Parse first part
C. Redate the metadata
ADateString := ExtractDateString(AImage.FileName);
//Say(ADateString);
ADt := DateStringToDateTime(ADateString);
if ADt <> 0.0 then
begin
//Say2(ADateString, DateTimeToStr(ADt));
RedateImage(AImage, ADt);
//sleep(1000);
end;
end;
var
i: Integer;
APro: TxomProgress;
begin
APro := TxomProgress.Create(nil);
try
APro.Caption := 'Redate from file names';
APro.Max := Selected.Count;
APro.Pos := 0;
for i := 0 to Selected.Count - 1 do
begin
APro.ProgressText := Selected.Items[i].FileNameOnly;
APro.Pos := i + 1;
HandleImage(Selected.Items[i]);
end;
finally
APro.Free;
end;
end;
Re: Redating from date in filename
Thank you very much, Hert. This is what I was looking for to get me on the correct way. Thanks!
In the Details tab of Photo Supreme (v4), for one jpg photo, `Date Time Original` is empty. No value in this field, and it not editable either in the app. However, if I run exiftool on the file, it shows `Date Time Original` value populated with the correct date time.
Why isn`t PS showing the metadata value that exiftool can see?
[edit] Files in this situation are all synced.
Thanks!
Fabris.
Thanks!
Fabris.
That file most likely has inconsistency between Exif/IPTC and the higher level XMP metadata. ExifTool shows Exif metadata, and PSU shows XMP metadata. Some tools out there do a bad job keeping metadata consistent at all metadata levels and only write Exif or only write XMP or even write partial XMP.
PSU offers a feature to fix such inconsistencies. Try this;
1. Right click on the file
2. Select "Metadata -> Convert metadata to XMP"
Thank you again Hert! this solves the date issue and actually many other metadata fields get populated once I execute this command (eg the 'Technical' group fields). It is strange because these are photos taken with the same cameras than other photos which had no issues with metadata.
Anyways this helps me a lot, thank you once more!
Fabris.
Fabris.
It’s not about the camera, but about the software you’ve used on these images.
I've used a few before centralizing in PSU, highlights the importance of consistency.
Thanks again for all the help here!
