Sometimes I have MP4 files that do not generate a thumbnail within Photo Supreme (Build 2025.1.8.7761).
Thumbnails show up in the MacOS folder using icon view.
I Rebuild Thumbnails within PS2025 and it doesn't help.
Aside from that, the MP4 file opens up and plays without an issue.
Is there a way to fix this?
Some MP4 Thumbnails Not Generating
Re: Some MP4 Thumbnails Not Generating
Yes I've noticed this as well under Windows, haven't found away of getting specific ones to generate, even after removing from DB and rescanning the folder, I suspect that it might be the way a single full frame is selected to be the thumbnail perhaps ?
Yeah I'm suspecting thats the problem.
Any insight into how Photo Supreme does this?
If you only have a few, then it may be quickest to manually add one using Mp3tag (if you're on Windows).
