States/Aspect Ratio/Ratio Square Issue
wesstl
Post by wesstl »
When I select aspect ratio square in the States section I get many images that aren't square. I'm seeing some 4x5, some 3x2, some 16x9...there doesn't appear to be any rhyme or reason as it's all formats as well: some tiff, some jpeg, some raw. All the other ratios appear to return the correct images except for square. Anyone else seeing this?
Re: States/Aspect Ratio/Ratio Square Issue
Just checked mine under Win11 and only square images appear for me.
wesstl
Post by wesstl »
Thanks. I should have said I'm on macOS Sequoia 15.3.2. I did just upgrade to Sequoia so don't know if it's related. I'm also having issues with thumbnails after the update but that's for another post.
wesstl wrote: 27 Mar 25 16:17 Anyone else seeing this?
Yes. I can confirm this on MacOS Sequoia. I use both MacOS and Windows11 so I will check it morning on my Windows Machine and send report to Hert.
apanella
Post by apanella »
Win11; PSU: 7494; States/Aspect Ratio/Ratio Square; works as expected for me.
Sorry, no MacOS versions in my world (yet)
@wesstl,
I'm not quite sure if I've understood hert correctly. You can try to recreate the thumbnails for images that are incorrect. It has worked for me so far but not for all ratio options.
wesstl
Post by wesstl »
RobiWan wrote: 28 Mar 25 16:49 @wesstl,
Are you still having issues with this? Did you report it? I've noticed a number of bugs that I've posted about haven't been addressed in the lastest updates so I'll report them if that will get someone to look into them.
