I edited a photo by cropping and scaling, then saved the photo (via Save Image). The thumbnail looks correct, but the file has not changed. When I open the photo in the viewer, the recipe icon shows. It appears that Save Image is only saving the recipe, and not altering the file, which is what I want. Save Image As does the same thing.
On top of that, when I open the photo in the viewer, only the cropped image appears, not the scaling I applied to it. Though if I open the Scale interface, the changes I made are there, they are just not reflected in the image.
I tried this on multiple photos, but the result is the same. I edit photos in this manner often, but not for a few months, so I don't know how long it has been like this. I was on version 6344 when I did this. I've upgraded to 6355, no change.
I'm on an Intel iMac running the latest OS.
save on edit not working
Re: save on edit not working
What is the file type you are editing? And as what file type are you saving?
I just tried it here and "Save Image" is saving with the recipe applied. It used a RAF file, added a crop, saved as a WEBP and the WEBP has the crop applied
These are all jpg images, and Save Image just overwrites the same file.
I couldn't tell from your response, but did you examine the actual file on the system (the Finder for the Mac)? After I save, I see both the Created and Modified dates are changed, so a save is occurring, but the image is not changed, so the crop is not saved to the file, it is only saved within PSu as a recipe.
Also, you didn't mention scaling. This is not even being saved within PSu as a recipe.
In regards to where I said scaling is not being saved, I just found that it is only scaling up that is not saved. Scaling down is saved. Regardless, it is still only saving as a recipe with Save Image, and not altering the actual jpg file.
I forgot to ask initially, but does anyone else see this behavior?
