Stacks
crabuback
Stacks
Post by crabuback »
How can I keep Photo Supreme from making stacks? I keep getting stacks showing up and I don't want them. I've changed the settings for Stacks in Settings, but it doesn't seem to matter.
xcalvov
Re: Stacks
Post by xcalvov »
I suffer from the same problem. Stacks seem to be created automatically. Despite I can change the rule, I can't disable the creation.
Re: Stacks
Stacks are not created automatically. They can only be created automatically if:
* you've selected that option in the Downloader (ingesting)
* you've selected that option in the Verify Folder results window
* you're importing from ICS and there previously was a stack for that image which is in the metadata
Best to check your ingest profile or if you're using Verify Folder, make sure to untick the option to create stacks and/or versions
crabuback
Re: Stacks
Post by crabuback »
It must be with the Verify Folder result window, but I don't know where that is or how to change it. This only started to happen recently, but I hadn't changed anything that I am aware of. Please tell me what to do to eliminate this from happening.
Re: Stacks
When are these appearing ? Is it after an Import, after a Verify Folder or what action are you taking before they appear ?
If they already exist and appear as you browse images then, click on States, open Stacked, select Stacked then select all the Images, right click and select Stacking and then Unstack this will then destroy all the stacks that exist. After this you won't have any stacked images at all.
roddyt
Re: Stacks
Post by roddyt »
As far as where to disable stacking or versioning, for the Verify Folder interface, uncheck the boxes at the lower left:
Screenshot 2024-03-02 at 6.20.48 AM.png (466.35 KiB) Viewed 3296 times
If during import, select the "More settings" button, then uncheck the selections as shown here:
Screenshot 2024-03-02 at 6.23.39 AM.png (274.1 KiB) Viewed 3296 times
xcalvov
Re: Stacks
Post by xcalvov »
Thanks a lot Hert and friends for your help. My case should have been in the ingest process. Problem solved!
crabuback
Re: Stacks
Post by crabuback »
roddyt - That's what I needed. I totally missed that box in the lower left corner during verify. Haven't seen any new stacks lately!
