PS 2024 crashing - empty hamburger menue
siehorst
Post by siehorst »
Hi, beside all the symptoms already described here, there is another symptom:
clicking on tha hamburger shows just a blank, white rectangle without any content.
clicking a second time will crash PS.
horst
siehorst
Re: PS 2024 crashing - empty hamburger menue
Post by siehorst »
Hello and good evening,
All problems are still there.
It's not just the hamburger menu, but also Help and Settings that shows a white rectangle with no items.
But now the surprise:
When I start PS with the default empty PS system database everything is fine - all menus are fine.
Now when I open my default database from the file menu, everything seems to be fine, and no thumbnail import.
horst
What Operating system are you using ?
siehorst
Post by siehorst »
sorry, with the laptop win 11 up to date.
Initially I thought if it is an issue with the grafic card, I am using an RTX ADA 2000 (for video editing) , but with the intel GPU the same.
horst
siehorst
Post by siehorst »
Hi, just updated but no changing with 6246
vkfoto
Post by vkfoto »
I'm in the middle of importing a lot of images, in small batches, when I noticed the blank menus too. The import process has not stopped. This in 2024 build 6246. Also crashes if I click inside the blank, not if I click anywhere else.
Parfumeur
Post by Parfumeur »
I get exactly the same blank menu and crash. When I initially check the menu is as it should be. But later, I know not the trigger, I get a blank menu. When I guess at the Exit location, it does exit. Description by others follow my findings and issues,
At other times after relaunch, it will crash if I click on the screen. Constantly
>> Lenovo W541, 32GB mem, 2TB SSD and 4TB SSD, OS Win 10 [64] with all the patches; photos, database and catalog on a Drobo 5D with 240GB SSD [BP4e mSATA] cache, 24TB storage using 2x6TB Ironwolf ST6000NE000-2EN and 3x4TB Hitachi HDS72404, PS 2024 2.0.6516 [64], connection via USB 3.0, <<
This has been going on for 2-3 months and we keep hoping the next release will fix the issue.
Anything I can do to help diagnose this issue? Debug file?
-= Chris =-
Hi Chris, a warm welcome to the forum and sorry to read about your issue.
This is a user-to-user forum. For support you can contact support@idimager.com
As a fellow PSU user here, my first suggestion would be to try to use some sort of monitor scaling (even 101% if you use a low res monitor) as this seems like a drawing issue.
Parfumeur
Post by Parfumeur »
> For support you can contact ...
Thank you, logical! Will do.
