LAP marker that indicates a Category when the Category uses a custom color
A few thoughts after this new addition in build 4883:
1 - The marker seems to show up even if the category uses a default color. From the description, presumably (I hope) this shouldn't happen? Maybe it's been triggered because I have additional top-level categories?
2 - So I've not yet got used to the markers, but I'm not keen on having the markers dotted around 'randomly' (OK, so they're not actually random, but visually they appear so) - I find them distracting:
If I must have colored markers, I'd prefer them to be grouped by color. Though I'd prefer not to have them at all.
3 - While on the topic, my preference would be to change the order in which the 'buttons' are displayed, so that they read the same way as reading text - that is, left to right, then down a row. Rather than down a column, then back to the start of the next column. Just me?
Re: LAP marker that indicates a Category when the Category uses a custom color
Have to agree that the labels would be nice ordered at times, but not quite sure what order, maybe best to be able to choose optional ordering scheme when it would be useful but some times its nice to have the same ones in the same position each time ..... keeps thinking!
If you don't like the markers then a quick tip: set the color in the Category details to fully transparent.
Hert wrote: 15 May 23 8:53 If you don't like the markers then a quick tip: set the color in the Category details to fully transparent.
Yes, that works, thanks :)
Filmoni
Post by Filmoni »
Can you please help me to understand this new feature, the way it works seems erratic on my pc ?
First screenshot : Category with a custom orange color -> Grey LAP marker
2nd screenshot : Category with a custom green color -> Grey LAP marker
3rd screenshot : Category with default color -> No LAP marker
4th screenshot : Category with default color -> White LAP marker
Thank you
Mathieu
It is the background color that is displayed in the triangle. Looking at your screenshots (nice picture btw) your categories have a font color but no background color.
Filmoni
Post by Filmoni »
Hert wrote: 17 May 23 10:15 It is the background color that is displayed in the triangle. Looking at your screenshots (nice picture btw) your categories have a font color but no background color.
Thanks for the clarification and the compliment !
It works well.
Mathieu
Sigi
Post by Sigi »
What are these markers actually good for?
Sigi wrote: 17 May 23 12:56 What are these markers actually good for?
So you instantly recognize what Category a Catalog Label is part of.
