Import to Catalog
hip2b2
Import to Catalog
Post by hip2b2 »
I regularly add new photos to my PS catalogue: Shift-Cntl-I / Start Import.
My problem is that one of the subdirectories should be excluded from the import. I exclude it, and it each time I run the update routine it gets added back in to the catalogue. Is there any way to make this permanent? Any suggestions?
hip
HCS
Re: Import to Catalog
Post by HCS »
I believe that you should once use the dialog and choose save at the moment of import. I'm quite certain it will then stick (at least for me it does).
Assuming you have a standard naming format then see this thread you can pre-set many actions types viewtopic.php?p=125688#p125688
