Hi, as I have more than one database I would like to see more than one - the last used - in the log in dialogs file list. It is a bit boaring always to be forced to use the 'select folder' dialog.
horst
File list in the log in dialoge
Re: File list in the log in dialoge
Nothing to stop you using separate desktop Icons with different command line parameters to open the required database.
See pages 10/11 of the Maintenance Manual https://manualsu.idimager.com/version7/ ... enance.pdf
High Geoff,
thank you for the reply, but
Strg Shit C only shows me the last DB used (and the initial one one that is located in the users diretory at the C drive I don't use).
And, if I try to quit Strg Shit C I get the dialog box attached. I can't quit that box but have to leave via the TaskManager
horst ( DK8AB
horst ( DK8AB
Ah maybe you need to tell us which Operating system and database type your using ?
Can't say I have ever seen that dialog box ever, maybe Hert can identify it ?
True: win 10, 64 bit single user.G8DHE wrote: 18 Sep 22 18:18 Ah maybe you need to tell us which Operating system and database type your using ?
One catalog database is located at a local NAS.
horst
so no chance of getting a kind of 'recently used catalogs' file select box like I would expect in a drop down list?
horst
horst
The drop down is intended to display catalogs that exist in the standard catalog folder or in the same folder as the catalog you have currently open.
I very much liked Geoff's suggestion to create different shortcuts to different catalogs.
As a side note: storing catalogs on a NAS is tricky. SQLite is not a network database and was never designed with network use in mind. SQLite performs slow on a network share.
Apart from that, SQLite creates constant "journal" files and the slightest network hiccup can corrupt these files causing total database file corruption. Make sure you have multi-generation backups available.
In general: place your catalog on the fastest possible internal SSD drive and make sure that the catalog folder is excluded from any virus scanner. You can use file sync tools to sync your files to/from the NAS, also on different computers using the NAS as a medium.
Don't worry
The shortcut method ist not working for me or I don't understand.
horst
