Hello
I use the dynamic search quite extensively in my workflow when I want to quickly search for some photos based on certain criteria.
I have recently come across the following issue: the dynamic search based on ISO value does not return all files from the catalog that it is supposed to.
For example:
1. If I choose the "DETAILS>TECHNICAL>ISO speed ratings>6400" from the catalog sections on the top of the PS window, I get all 128 of my photos matching that criteria (a mix of RAW and JPG files).
2. If I filter the folder where the photos are stored with the "filter by macro command" from the filter section (ISO Speed Ratings contains value 6400), I also get all 128 photos.
2. If I drag the "6400" label from the "ISO speed ratings" into the dynamic search box, I only get 1 photo as a result. All the others are missing.
I do not see why the result is different. It works OK for "F-number" and "Exposure time" but not for ISO. All the needed information is obviously present in the metadata and is properly ingested in the catalog, since I can filter it out. Manually checking "info" or "details" tabs of each photo also correctly shows "ISO 6400". But the dynamic search cannot see it for whatever reason?
Dynamic search on ISO value not returning all files
Re: Dynamic search on ISO value not returning all files
Please update to build 4306.
Thank you Hert. It is working correctly in build 4306.
