Upgrade to v7 & switch from server to single-user
Al_M
Post by Al_M »
So after a couple of years running the server version, I decide it wasn't for me and would like to switch back to the Single-User version.
Currently running v6 Server. Upgraded to v7 trial Server edition (yes, made backups).
I ran the application and allowed the database to be upgraded to v7.
Then installed v7 trial SIngle-User. Opened it once and closed it.
Ran the Data Exchange tool and converted the database from PostgreSQL to SQLite.
After the tool ran it gave me this message:
Screen Shot 2022-04-26 at 2.58.30 PM.png (19.33 KiB) Viewed 2907 times
OK, so I keep going. Open PSu (single-user) and it appears my data is intact.
However my folders show red icons:
Screen Shot 2022-04-26 at 8.36.36 PM.png (178.38 KiB) Viewed 2907 times
Weird that the top level and year level folders appear without the red icon, but below that (month and day levels) have it.
I tried to "Map to the Correct Physical Folder", and after a message that Folders were successfully mapped, nothing has really changed.
My external drive is connected and mounted.
I re-opened the server version and it has no issue seeing my folders, but for some reason the single-user version can not.
Server version mapping working just fine:
Screen Shot 2022-04-26 at 3.46.21 PM.png (172.5 KiB) Viewed 2907 times
I suspect that error may have something to do with it, but who knows?
I haven't rebuilt thumbnails yet, but that shouldn't have anything to do with folders being mapped...
Can anyone help me?
Photo Supreme V2024.x Single User Edition
Mac Pro (Late 2013), 3.0 GHz 8-Core Xeon E5, 64 GB DDR3, macOS 13.6 (Ventura)
MacBook Pro (Mid 2015), 2.5 GHz Quad-Core i7, 16 GB DDR3L, macOS 12.7 (Monterey)
Re: Upgrade to v7 & switch from server to single-user
Thank you for choosing V7.
Can you tell me:
1. What V6 build (the last 4 number of the version number) you had installed before (if you recollect)?
2. Are (some of) these folder symbolic links?
About the idSearchData error you got in the migration.
In case you want to rebuild all of your search data (note: this may take a while to complete) then run this script (hamburger->Tools->Scripter):
PublicCatalog.BuildSearchData;
Say('done');
Again, this may take a while to complete, during which it may appear that the application installed.
Al_M
Post by Al_M »
Hert,
Server v6 was build 4216 (the latest, I believe) before upgrading to v7 Trial.
None of the folders are symbolic links.
Would it be possible to send a copy of your cat.db file? No need for the thumbs db.
Best to upload a ZIPped copy to a cloud drive and send a download link to support@idimager.com
Al_M
Post by Al_M »
Hert,
I sent you a link as requested.
Please let me know if you have any issues downloading it.
Thanks.
Thank you. I've replied to your email with a link to your corrected database.
Al_M
Post by Al_M »
Hert,
Thank you. Seems to be working now.
As usual, thanks for the quick response!
