Looks for Metadata
Henri T.
Looks for Metadata
Post by Henri T. »
In the "Details" section, in the "Technical" panel, I have no information on the settings of my camera: date, focal length, exposure time, ISO ... I only have the name of my camera. Canon EOS R5 camera. How can we find them and display them. I specify that during the export / import, my metadata are included.
Thank you
---- ORIGINAL TEXT ----
[ Cherche Métadonnées ]
Bonjour,
Dans la rubrique "Détails", dans le panneau "Technique", je n'ai aucune information sur les réglages de mon boîtier : date, longueur focale, durée d'exposition, iso ... je n'ai que le nom de ma camera Canon EOS R5. Comment peut-on les trouver et les afficher. Je précise que lors de l'exportation/importation, mes métadonnées sont bien inclues.
Merci
[Edit Hert; the language for the forum is English. If English is a problem then you can always use a translating service (like Google Translate) to translate your text to English. In this case, I've translated the text with Google Translate]
Re: Looks for Metadata
Your images probably have partial XMP but the tool that created that XMP failed to convert the exiting metadata to XMP. Photo Supreme can fix that for your.
Try this:
1. Right click on your images
2. Select Metadata -> Convert metadata to XMP
Henri T.
Post by Henri T. »
It works, it's good, thank you very much!
