Error when photo on Google Maps
Frits de Witte
Post by Frits de Witte »
Ik heb Photo Supreme V6 geïnstalleerd op m'n PC en op m'n Laptop.
Op de PC werkt alles correct.
Op de Laptop komt een foumelding als ik vraag om een foto op
Google Maps te tonen:
Fout opgetreden in het script op deze pagina
Regel 57
Teken 1
Fout: De eigenschap of methode addEventListener wordt niet ondersteund
door dit object
Code 0
En er komt een URL naar BrowserEvents.js
Op beide computers heb ik dezelfde API-key ingevoerd bij de instellingen van PS V6
Wat is er aan de hand?
Hoe los ik dit op?
Groet,
Frits de Witte
Re: Error when photo on Google Maps
Hi Frits,
This forum if for everyone to read and requires English as the language. Sorry for replying in English
The message you’re getting is related to a missing registry setting. This setting is set in the installation.
Try this;
1. Redownload the installation file
2. Right click on the installation file and select “Run as Administrator” (iets als “Als Administrator uitvoeren” in een Nederlandstalige Windows)
3. Install over your existing copy
4. Once installed, start PSU and try again
Does that help?
Thank you
Frits de Witte
Yes! It works. Thanks a lot.
Perhaps a good idea to tell this in the installation instructions.
snk
Post by snk »
Dear all
May be this helps to understand what could lead to the issue on a Windows system:
Imagine the following scenario:
Google Maps works with Installed version of PSU (in my case PSU 6)
Upgrading to version PSU 7, Google Maps worked with PSU 7
After removing PSU 6 from the system, Google Maps cheases to work in PSU 7 (deintallation removes the registry key)
As Hert stated, running the PSU 7 installation again solves the symptom
Another option would be to remove the previous version(s) of PSU prior to installing the new one
Seb
nikcob
Post by nikcob »
I updated to version 7 (after that I deleted version 6) and had the same problem: no google map in the geo panel. Reinstalling version 7 does work!
Thanks!
