Export Location Shown/Created
RobertB
Post by RobertB »
When I right-click -> Metadata -> Export Metadata to CSV File on photos, the data for the Location Shown (Iptc4xmpExt:LocationShown.Iptc4xmpExt) and Location Created (Iptc4xmpExt:LocationCreated.Iptc4xmpExt) fields are not being exported. Any idea why that might be happening?
Also, is there a way to export to a CSV file the labels that are assigned to photos?
Re: Export Location Shown/Created
Hi Robert, First of all a warm welcome to the forum.
Great find. LocationShown and LocationCreated are arrays of structures. PSU doesn't know which element to pick. Since you can't configure that the next update will always default to the first element, which will allow you to export such fields
If you use PSU with its standard settings then catalog labels are also in dc:Subject (Keywords). Select that in your CSV export.
If that doesn't provide all labels (e.g. when you have private labels and also want to export those), then try this:
1. Open Info Panel
2. Create a new Custom Field of type "Macro Field"
3. Use the macro: %CatalogLabelList
4. In the Export to CSV you can now select your newely created custom field
Define a macro custom field
RobertB
Post by RobertB »
Export of labels to CSV file works great.
Look forward to the next update!
You can now download and install build 2945 from the website.
RobertB
Post by RobertB »
LocationShown and LocationCreated fields now are now being exported as requested. However, these two are now not showing up in the Details panel.
You can now download and install build 2948 from the website.
RobertB
Post by RobertB »
It works.
Thanks!
RobertB
Post by RobertB »
Sorry, I spoke too soon. I see the two fields backs in the Details panel but unfortunately the fields are now not being exported again.
Hopefully, the third time is the charm. You can download 2952
RobertB
Post by RobertB »
Both the export to a CSV file and display of the fields in the Details panel are working!
