Customizing the grid view columns
jsrunnels
Post by jsrunnels »
I posted this to the mantis feature request site about 2 months ago, but I don't think anyone has seen it there. I am trying to migrate over from Media Pro and the thing I am going to miss most is the ability customize the columns in the grid (list) view.
I utilize the grid view in Media Pro extensively to batch tag and check my photos with categories, keywords, locations, etc. Is there a way to increase the number of options for the column headings?
Media Pro allows you to add essentially any metadata catagory as a column with two clicks. You can see all the options that MP gives you in this screenshot the screenshot I attached to my mantis request (I am not allowed to post URLs here yet).
Re: Customizing the grid view columns
A warm welcome to the forum.
You can add custom fields in the Info Panel. Custom fields also appear in the grid view.
PS. also check https://www.youtube.com/watch?v=H4TpHOcD4vU
andrew.heard
Post by andrew.heard »
jsrunnels wrote: 21 Sep 19 23:43 I posted this to the mantis feature request site about 2 months ago, but I don't think anyone has seen it there.
IMHO this is a limitation of the split between forum topics & the bug tracking system. I follow the forum but not feature requests. Your request sounds good. I don't use grid mode due to its limitations. I'd vote for your request. What is the URL?
jsrunnels
Post by jsrunnels »
Thank you, Hert! That looks like exactly what I am after! I will give it a try as soon as my thumbnail database finishes compacting.
Andrew -- I tried to put the URL in my original post but am barred from posting URLs. (I assume because I am brand new.) But the summary description is: "0003364: Grid View Columns (coming from Media Pro)" and it is just fifth from the top in the recent list.
andrew.heard
jsrunnels wrote: 22 Sep 19 13:24 Andrew -- I tried to put the URL in my original post but am barred from posting URLs. (I assume because I am brand new.) But the summary description is: "0003364: Grid View Columns (coming from Media Pro)" and it is just fifth from the top in the recent list.
thanks, Will add my +1 FWIW
jsrunnels
Post by jsrunnels »
I just wanted to circle back here and say that the custom fields works perfectly and does exactly what I need it to. It would be great if we could get it as a right-click dropdown on the column header bar, but that is a relatively minor quibble. Thank you, Hert for showing me how to do it!
