Number Next to Filename in a Thumbnail?
Newbie
Post by Newbie »
In thumbnails, there's a box with a number in it to the far right of the filename. Most thumbnails have a zero in that box, but a number of others have a number ranging anywhere from 1-9. What does that number mean, please?
wesstl
Re: Number Next to Filename in a Thumbnail?
Post by wesstl »
That's the number of Catalog Labels applied to that image. If you roll over it you'll see the labels.
If your not sure of anything use Shift-Ctrl-T and then hover the Mouse over the item and the Tips will come up, or lower left corner "Help" menu has the info on various help items.
Newbie
Post by Newbie »
Thank you both for your helpful replies! This is a feature-full app, and it is taking a while to learn. But I'm liking it a lot!
