PSU Update 2025.1.3.7602 > Catalog label window much too small
JensSteyer
Post by JensSteyer »
New PSU Version
> Folder
> Right > Catalog Label (blue)
> The catalog label "window" is much, much, much too small these days - why?
That's very bad, Hert, you have to scroll constantly!
Please set it back to how it was before, or even better, make the "window" (with the labels for each image) resizable.
JensSteyer
Re: PSU Update 2025.1.3.7602 > Catalog label window much too small
Changes like the one I just mentioned really annoy me; they completely impair my work with labels.:(
So, one more question: Is there a way to download the previous version? It's much more useful to me than the current one. (The PSU update didn't make any changes to the database.)
andrew.heard
Post by andrew.heard »
ha ha - I just emailed Hert directly, before reading this post. Am in total agreement. To summarize...
with release #7602 that the LAP is now a "static" size. It's now also half the size (or less) of the previous version so I can't see most of the assigned labels - only 8 are visible at one time, mostly cluttered with AI labels, and I can't find any splitter control to resize the panel. By contrast the size for RECENTLY USED & SUGGESTED is far larger. I don't use any of the other subsections of the LAP, purely the top "currently assigned" subsection, so (dynamically) maximizing this section (like before?).
manusz
Post by manusz »
When you are on a Mac you can use Time Machine to restore a previous version of PSU.
andrew.heard
manusz wrote: 18 Apr 25 5:58 When you are on a Mac you can use Time Machine to restore a previous version of PSU.
Thanks. I keep previous versions & could go back, if compatible database. But not really a useful strategy for me.
JensSteyer
Hello sufferers, luckily I'm not the only one with this problem.
I'm using Windows 11 Pro, and I've decided NEVER to use automatic updates again. I'm really extremely annoyed. :evil:
Happy Easter to you all.
I'm confused I'm on 7602 and the Label Pane can be expanded as normal by dragging the boundary as normal ?
Screenshot 2025-04-18 093339.jpg (381.58 KiB) Viewed 19813 times
JensSteyer
G8DHE wrote: 18 Apr 25 8:37 I'm confused I'm on 7602 and the Label Pane can be expanded as normal by dragging the boundary as normal ?
But not in the “Folders” tab - that’s the point, Geoff.
It makes no difference which Tab your in ?
Screenshot 2025-04-18 105120.jpg (329.15 KiB) Viewed 19786 times
Just click on the boundary and drag to te size you want, same for the lefthand panel!
JensSteyer
It looks completely different for me, Geoff – where, for example, do you have the "blue-marked" labels, i.e., the labels per image?
JensSteyer
One request: If anyone doesn't do a web update anyway and still has the latest Windows version (a not-too-old one before the one mentioned above) as their setup, it would be great if you could provide it to me as a download. My last backup was from March 6, 2025, which is too old; PSU apparently updated the database in the meantime.
THANK YOU :)
Here is a Youtube of dragging the Panel width https://youtu.be/ScAcOkz5MlU Mine isn't showing Blue labels as I haven't selected anything so they remain Black. but the side Panels either side can be adjusted, run your Mouse over the Boundary and then click and drag as per the video.
JensSteyer
@Geoff
Thank you for your idea. I'm not the only one who is extremely bothered by the new behavior.
I found and installed a previous version, 2025.1.2.7566, and now everything looks the same as before. :)
I can't see that anything has changed, the Panel widths can be changed as required as has always been the case ?
Have you actually tried dragging the boundary line of the panel to the width that you want ?
Ah are you referring to the height of the "In use labels" rather than the entire Label panel maybe ?
