Looking for a tip: Found an image via search > what's the most reliable way to get to the image folder?
JensSteyer
Post by JensSteyer »
I thought you could get to the image folder using SHIFT+CTRL+ALT+F. It sometimes works, sometimes it doesn't....
If I do everything with the mouse (right-click > More > From folder "xyz"), it always works:
freudenthaler
Re: Looking for a tip: Found an image via search > what's the most reliable way to get to the image folder?
Post by freudenthaler »
Well, if it's just to go to the folder of the selected image, then you have the "Anzeigen in Windows Explorer"-menu-item (Shift+O) available...
