What I really don't like is that copying all catalog labels from one image to another adds them together. For example, if I click Insert Catalog Labels three times, all the labels are also included three times in the target image....
I think this is a bug. Or at least there should be a way to specify whether the inserted labels should be added together or replace the existing ones.
Problem: Copying all catalog labels from one image to another
Re: Problem: Copying all catalog labels from one image to another
If you mean 'Paste Labels from Clipboard', for me (on Windows) it only pastes them once. But maybe 'Insert Catalog Labels' is something else that I can't recall?
Ha, I've just realized something:Mke wrote: 01 Apr 25 19:42 If you mean 'Paste Labels from Clipboard', for me (on Windows) it only pastes them once. But maybe 'Insert Catalog Labels' is something else that I can't recall?
It's not the copying and pasting of the catalog labels that's causing the problem, but rather the subsequent insertion of my profile (Tab > Details > Profiles > My Default Profile).
Brief explanation: I've been working with PSU for about two years. When I publish an image, I add my default profile, including the copyright, via > Details > Profiles.
Sometimes, all existing labels appear twice. This is what it looks like after adding my default profile (it's really annoying): How can I prevent this?
