[solved] Info-Window and Light Table
JensSteyer
Post by JensSteyer »
I would like to display the very nice and clear info window permanently (preferably "floating"). Is this possible?
I haven't yet realized the benefit of the "light table". How can I hide this tab?
Re: Info-Window and Light Table
JensSteyer wrote: 29 Mar 25 13:17 I would like to display the very nice and clear info window permanently (preferably "floating"). Is this possible?
No, however you can recreate most of the same information below every thumbnail by creating a 'Custom Thumbnail Style'. For example, mine shows:
rating (interactive); ISO; sharpness
file format; file size; image size; aperture; shutter speed
collection marker, time, GPS
JensSteyer wrote: 29 Mar 25 13:17 I haven't yet realized the benefit of the "light table". How can I hide this tab?
No, but it's essential for comparing similar shots side-by-side, so you'll probably want it sooner or later!
JensSteyer
Thank you for your tip about configuring it yourself. :)
I actually already knew that this was possible with software like this. :)
I also found the icon and (albeit a bit tediously) now have exactly the display I want:
JensSteyer wrote: 30 Mar 25 10:16I also found the icon and (albeit a bit tediously) now have exactly the display I want:
Good idea to save the codes to a text file, in case you need to reinstall PSU at any time.
JensSteyer
Mke wrote: 31 Mar 25 19:29
Don't worry, it's already backed up in my cloud. :)
