Saved loactions in Geo Tag missing
I used to have a number or saved locations in Go Tag and I can't find any thing there now in 2025 to either use or save as locations.
Re: Saved loactions in Geo Tag missing
Have you looked on the bottom line, under Favourites ? All those options have moved to the bottom.
IWill look when home, not the most obvious thing!
I cant see any Favorites any where
- Screenshot 2025-02-24 145256.png (33.46 KiB) Viewed 18130 times
You appear to have pushed off the righthand border ?
[ external image ]
[ external image ]
- Screenshot 2025-02-24 152923.jpg (20.67 KiB) Viewed 18124 times
No not there
Something wrong its the same on both my installs no sign of Favorites when filling screens or reduced in size. My installs are from the update link given by Hert
You may have to drag the GEO panel wider
Yes that's it but on my laptop (its just a 15inch) it's losing too much of the images so will only open out if needed. The old location wasn't a problem. Its also not carried over any of the old locations which is a pity so will have to rebuild the list again. Oddly they were on one install but not the other, I use the scrip to update between the two so just copied again between the two strange why one lost the locations but the other hadn't.
Favorites moving to center saves it on a small screen, thanks!
