Searching for Items Without a Version Set
wesstl
Post by wesstl »
I see how I can use the Types section to locate version sets but is it possible to search for images that are alone/not in a version set? All my processed raw files have a working image in the set but I'd like to search a folder of images for raw files that have no processed files. These are the images I haven't worked on yet so they have no other files in the set. Maybe it's possible and I'm just missing it. Thanks.
roddyt
Re: Searching for Items Without a Version Set
Post by roddyt »
In the State menu, hold down the option key (alt, I think, in Windows) and select Version Sets. That should get you what you want. Holding that key, in effect, is like adding NOT to a selection.
wesstl
Post by wesstl »
roddyt wrote: 23 Feb 25 11:50 In the State menu, hold down the option key (alt, I think, in Windows) and select Version Sets. That should get you what you want. Holding that key, in effect, is like adding NOT to a selection.
I had no idea you could do that. Thanks a lot.
