Adding to multiple portfolio collections
marklevine
Post by marklevine »
This is a suggestion for an enhancement. I would be nice if the dialog box entitled "Select a collection to add these images to..." was enhanced to allow extended selections via Shift-Click and Ctrl-Click. The title of the dialog could be changed to "Select collection(s) to add these images to...".
I frequently need to add an image to multiple collections. This operation is awkward, starting with a right mouse click on the image to be added. It would be more efficient to use Ctrl-Click to select all relevant collections before clicking OK.
HCS
Re: Adding to multiple portfolio collections
Post by HCS »
I think that would be nice (i haven't tried whether some key combination is already possible).
On the other hand, if you are adding one image to multiple collections, are they/could they be rule based. That is easy to set up and would reduce/eradicate the manual work.
Based on your forum post, nothing will happen. You'd want to add this to the ticketing system for PSU. The correct link is in the description of the posts of Hert, as i don't have that link.
marklevine
This is fixed in Version 2025. I can now select multiple collections in the dialog box and add the selected images to all at the same time. This is a really nice small enhancement to the new version.
