finding portfolios for a photo
jj95
Post by jj95 »
My situation is the following : I use portfolios to manage what "usage" I do for some photos.
Then : a photo can be referenced in many portfolios. For example : in the porfolio for club session, and also in the porfolio for a conference, ....
Is there a function in PS that could give me the list of portfolios where my photo is referenced ? I have not found that function in PS.
jj95
Re: finding portfolios for a photo
Post by jj95 »
The answer is here : viewtopic.php?t=32402
noramila
Post by noramila »
Thanks for pointing to the solution in the other thread! It’s good to know there’s a way to find the list of portfolios referencing a photo. This will definitely make managing photo usages easier in PS.
jj95
Post by jj95 »
Apart modifying the text below the thumbs, I found another solution much is more interesting.
The solution is to customize the "info" right window (when you click on the info button) ! In this window, it is possible to add "personal" fields.
So, in this place, I have added a new field which calls the macro : CatalogPortfolioList ! And I have also added a field with macro : CatalogLabelList.
Doing this, it allows to display Catalogs and Labels when selecting a picture.
jj95 wrote: 21 Jan 25 17:45 I have added a new field which calls the macro : CatalogPortfolioList
That's good idea - but what's the macro code?
roddyt
Post by roddyt »
Mke wrote: 22 Jan 25 23:25
The macro is a menu selection. Follow these steps:
Select New Custom Field > Add Macro Field
Enter a caption.
Click the pre-entered %FileName and choose Select Another Macro
Select Catalog > Portfolio List
Click OK
The macro itself is described in the Macro Commands manual. The only thing I don't think is possible is to add parameters, as defined in the manual, to the command. If it is possible, I would like to know how.
roddyt wrote: 23 Jan 25 19:05 The macro is a menu selection. Follow these steps:
Enter a caption.
Click OK
Thanks - that did it :)
I tried everything but that! Clicking on the menu; trying to overwrite %FileName with the macro code; deleting %FileName then trying to use the + button lower down...
For anyone else:
New Custom Field.png (10.91 KiB) Viewed 15606 times
I can't see a way to add add parameters either.
