Continuing the thumbnail building for 1 files
smadell
Post by smadell »
"Continuing the thumbnail building for 1 files"
This message comes up every single time I open Photo Supreme (v2024.2.2.6689 on a Mac Studio with M2 Max, 64 GB RAM, MacOS Ventura 13.7.1). Because it is a single file I do not know which thumbnail it is attempting to rebuild (the message appears and disappears too quickly to show up in the Activity panel). Because of this I cannot aim any potential fix at that file.
1) There are no "Out of Sync" files listed in the States tab.
2) There are no images in the Timeline tab dated 1899.
3) I have "removed" my last few imported folders and re-imported them.
4) I have right-clicked on the Top Level Folder and done a Verify Folder>Verify Folder Quick, and have corrected all of the files and folders that were found.
5) I then right-clicked on the Top Level Folder and ran a Verify Folder>Very Folder Binary. Numerous additional files were found, and these were processed at that time.
6) I chose Tools>Build Missing Thumbnails and Previews. It may have done something, but it was too quick to keep track of.
And yet, the error message shows up each and every time I open Photo Supreme. Any suggestions?
Re: Continuing the thumbnail building for 1 files
If you get the "Continuing the thumbnail building for 1 files" then that means that you have 1 file in the catalog without a thumbnail.
Try this to identify the file
smadell
Post by smadell »
You're the best! There are so many little touches hidden inside of Photo Supreme, and I never knew this sub-menu was there! I found the file and took care of the issue, all in the space of a couple of minutes. Easy peasy. Thank you, Hert.
