Show number of megapixels in image
manusz
Post by manusz »
I would like to show the number of megapixels an image has, either show it in a custom thumbnail or as a custom field in the Info panel.
From the Exiftool website I understand there is a composite tag called Megapixels which seems to contain what I would like to use:
https://exiftool.org/TagNames/Composite.html
When I open an image in XNViewMP there is indeed a Megapixels composite tag which gives me the value I am looking for.
I searched the Predefined and Macro fields in PSU but I can't find anything related to Megapixels.
Most likely I am overlooking something obvious……
Could someone please point me in the right direction?
Thanks in advance!
Re: Show number of megapixels in image
This should do it. Paste it as a custom thumbnail line.
%code
  if ('%ImageWidth' <> '') and ('%ImageHeight' <> '') then
    result := GetSizeString(StrToInt('%ImageWidth') * StrToInt('%ImageHeight'), ssMegabytes, False);
  else
    result := '--';
%/code Mpx
manusz
Post by manusz »
Thank you Hert, that works like a charm!
I guess scripting this means the composite tag is not available in PSU then?
The name "composite" means that it is a calculated field, derived from other fields...it is not a standard metadata tag.
In other words: ExifTool made up with that field and calculates the value based on data from other fields. That is also explained at the top of the page you linked.
manusz
Post by manusz »
Ah, OK, I see.
I just assumed the tag would be in the file and thus would be available PSU.
Anyway, the script you so kindly provided fills the gap.
Thank you for your support!
