Apologies if my question is too simple. I would like to export multiple jpegs from a folder of larger tiffs in an exterior drive. I am using the Share function. And 'Copy as Jpeg to Folder'. Also have selected 'Enable Resizing' and a longest side of 1800.
At the moment, Photo Supreme is creating smaller tiffs in the new folder? Rather than jpegs. Before that, it wasn't doesn't anything.
I'm not sure what I am doing wrong?
David
Copy as Jpeg to Folder Not Working
Re: Copy as Jpeg to Folder Not Working
A warm welcome to the forum.
Could be that you have changed the transfer profile?
Right click on the profile in the Share button and select "Details". In the File Naming, make sure that the extension is set to .jpg.
But perhaps it's easier to use the Export to Folder feature (Ctrl+E on Windows or Cmd+E on macOS)
Thanks Hert!
I do find the File Naming a little confusing. Is the bottom listing the name you want new? If so, how would I change tiff to Jpeg? I have attached a screenshot of what I am seeing.
Thanks. D
Thanks. D
- Screen Shot 2024-09-16 at 2.54.33 PM.png (820.13 KiB) Viewed 5093 times
Use "Edit as text"
There, enter
There, enter
Thanks so much Hert! It's working now.
