How to install V6 after V7 release
asherjackson
Post by asherjackson »
I have a licence for V6, but when I try to install it now, I can't get to the trial version because of "Please install the latest build.. " error message.
Is it possible to install the licence directly without going through the trial version?
Re: How to install V6 after V7 release
Welcome to the forum
asherjackson wrote: 30 Aug 24 3:36 Is it possible to install the licence directly without going through the trial version?
You have to copy the license file manually into the corresponding directory
(Windows - c:\users\YourLoginName\Appdata\local)
combineplover
Post by combineplover »
If you have V7 or any remnants of it installed, completely uninstall it from your system to avoid conflicts.
Ensure you have the correct V6 installer. If you don't have it anymore, you might need to contact the software provider's support to get a copy, as they may not make older versions readily available for download.
grinadhoc
Post by grinadhoc »
Thanks so much Combi! It's working now.
