Add colored icon on context menu
msw.photo
Post by msw.photo »
Hi all,
is it possible to show the corresponding colored icon in the context menu for the folder marker in addition to the name of the marker?
Kind regards
Re: Add colored icon on context menu
While you can set a color in the context menu. you can also click the folder icon to set a folder marker.
PS. this is a user-to-user forum. Feature requests or bug reports can be sent to support using the link below.
msw.photo
Post by msw.photo »
This is a solution, but, like much else in the app, very inconsistent in terms of UX.
Context menus consistently do not use icons in PSU.
msw.photo
Post by msw.photo »
Context menu of folder icons left-click, context menu of the folder description only one space removed right-click. Now it's your turn again.
"Context menus", at least to me, are the right click menus.
