No Selection in Image Viewer and Rating Quirk.
I sometimes have this issue where I'm viewing a folder of images and I double click one and the Image Viewer opens but doesn't show the image, instead saying No Selection. In this case it happened after another quirk where I was rating images found from a saved search and sorted by Photo Date. After giving a rating the image would disappear. Then double clicking on any image resulted in the No Selection. It didn't matter if it was the same tab or a different one. I was unable to view any images in the image viewer. Reopening the tab from the search would show the pics that disappeared with the correct rating but I still couldn't use the image viewer. A restart of the app restored the ability to use the viewer. I'm on build 6355 on a Mac.
- Screenshot 2024-05-01 at 12.01.06 PM.png (132.69 KiB) Viewed 2683 times
Re: No Selection in Image Viewer and Rating Quirk.
You are apparently using a floated viewer.
This can occur if you have no thumbnail selected. Eg when keeping the Viewer open, and then clicking on the background of the Collection Viewer (thumbnails area)
That's not what happened-I know how to double click an image-but, ok.
