Dynamic Search Sort Order on Cusom Field
Simon
Post by Simon »
Is there a way to set the search order / display order of images when using Dynamic Search?
Specifically, I have added three custom fields to my database: ProjectNo, ReportNo, PhotoNo.
I use Dynamic Search to select the photos for the report using the ProjectNo and ReportNo fields.
How can I then sort on PhotoNo so the photos display in order as listed?
Re: Dynamic Search Sort Order on Cusom Field
What is wrong in using the normal Sort button? Bottom of the screen just above the Basket count, click and select the sort order required for that display. As you have custom fields then you would need to use the Sort Script option button towards the bottom of the list and create a sort option that suits your needs.
Simon
Post by Simon »
Thanks Geoff.
I looked through the options but missed the : Sort With Script - Macro Command -> this lets you select the custom field to search on.
