This forum is a user-to-user community. It is a space for sharing experiences, tips, and advice among users. Official support is not provided here, nor is the forum actively monitored. If you have suggestions, requests or need support then please send a message.
I wonder if others would find a combined Image as well as a Route map display would be useful ?
At present the Route map can only be displayed when using the Geolocating panel, and the Image display on map only shows the locations of the images, I have posted a request on Mantis for an option to combine both on the full sized Image on map display if you think it would be useful please visit Mantis https://mantis.idimager.com/view.php?id=3545 and support the request
Screenshot 2024-03-20 103450.jpg (424.96 KiB) Viewed 1174 times
Just a thought could this be a new Feature used with the Attached Files function, in that a category of .gpx/.kml/.nmea could then be associated with the image file and used when the image is displayed on a mapping panel ?
Is there a mechanism for Attaching the same file to several images ? I'm thinking again about attaching Route information to images from an event the selected images will all need the same Route file attaching. As in the example with pictures above the single Route file (GPX type in this case) used to plot the positions of the images needs to be associated with all the images taken during the event.
I ask as I just tried it and expected all the selected files to have the same Attachment added but this is not the case only the single image file whose paper clip was clicked had the associated .gpx file added.
As a nice feature if images are positioned using the Geo panel perhaps a button to Attach the same .gpx file used to plot them could be attached to all selected files?
