Ignore folder option doesn't work anymore ?
Filmoni
Post by Filmoni »
I used the "Ignore folder option" in the latest PSU version and it doesn't seem to work as before.
The "ignored" folder isn't crossed out like before (see the screen capture)
Files aren't imported but when I used the "Verify folder" tool on the root folder, it still wants to add the files from the "ignored" folder.
It wasn't the case before.
Is it normal ?
Thank you
Ignore Folder.jpg (58.2 KiB) Viewed 9927 times
Mathieu
Filmoni
Re: Ignore folder option doesn't work anymore ?
Post by Filmoni »
Great, thank you very much for the fix in version 2023.2.0.5063 👍
Mathieu
