Do you know if it's possible to change the default areas type and size ?
Thank you
Default areas type and size
Re: Default areas type and size
Thank you for your answer.
Do you think it would be possible to do it with a script ?
Mathieu
Only Hert can advise on that, might be worth a message to support ?
Thanks for your feedback.
Can you specify where I should send this request? It's not done via this forum?
Mathieu
Well support@idimager.com or use the Contact link on the site home page ?
Or use Mantis to request a new feature https://mantis.idimager.com/
