Blurred characters in the app
jj95
Post by jj95 »
Dear all
Looking attentively to the characters used in menus, thumbnails, .... I noted this morning that they are not "sharp" as my other windows apps. It seems that characters are fully "graphic" in the app.
And then characters are somehow "blurred".
I am using the app on W11 with a 1920x108 ASUS monitor.
Display is 100% in Windows parameters
Automatic correction in Windows for blur in ON
Is there any settings to tests ?
Re: Blurred characters in the app
Difficult to suggest without seeing some of the text, this is a screengrab from my laptop Win11 Resolution 3840 x 2160 x 120 hertz
Screenshot 2023-04-07 132500.jpg (13.46 KiB) Viewed 2433 times
jj95
Post by jj95 »
Thank you for your screenshot.
I would like to display mine (but how can I upload images in this forum ?)
It shows clearly that title of the Windows window is sharp and that characters inside the app are less define (blurred with low resolution).
How can I solve that ?
jj95
Post by jj95 »
Strange ... coming back to PS and reopening the app this evening, the problem has disappeared .... ?!?
The only thing that I have done is to reactive the anti-blur option in Windows option.
That's good to hear, if you need to add attachments then click the option for the Full Editor at the bottom of the input screen, then extra items appear to allow uploading images etc.
