The Details Tab is Missing Metadata
tplunkett
Post by tplunkett »
Hello - I have been using version 2023.0.2.4840 on Windows 10 without issue but I just noticed that I have just a few pieces of Metadata categories on the Details tab. I usually have all sort of information in this area - I usually filter on Technical related metadata but it is no longer present. What is strange is I think just a few days ago it was missing, then an hour or so later it appeared (I thought maybe it was just taking a while to prepare and present it) but now it is missing again. I have used PS for a long time and have not experienced this before. Any help or insight is appreciated.
Photosupreme Details Tab.jpg (445.25 KiB) Viewed 1426 times
Re: The Details Tab is Missing Metadata
The Details section shows the fields of the editor you have selected in the Details Panel (click Details below the thumbs). From the looks of it you have the Basic editor selected there. The default is the Advanced Editor.
tplunkett
Post by tplunkett »
Thank You Hert - that is exactly what my issue was. Changed it back to Advanced and everything is displaying again properly.
