Adding photos to catalogue
hip2b2
Post by hip2b2 »
Absolute newbie, i.e., 20 minutes of experience.
I have created a catalogue from everything in my "Pictures" folder. I added a couple of new picture to the folder than ran: Select Verify Folder > Select Verify Folder Quick.
The catalogue is read, a window opens offering to add many (perhaps dozens) additional folders to the catalogue. Manually going through each of these folders each time I run an update to the data set seems unnecessarily burdensome.
What is the correct procedure?
Thanks and regards
hip
HCS
Re: Adding photos to catalogue
Post by HCS »
That is the correct procedure. Once added to the catalog, it won't ask again, just for folders or files not yet managed in the catalog.
Presumably these new folders are pre-existing under the "Pictures" folder ? Or perhaps you had a different folder selected ?
Larry56
Post by Larry56 »
I found just adding from Pictures was beyond my needs or wants. Too many apps will create their own folder under Pictures which I didn't want or need cataloged. My work around was to create a My Photos under Pictures and all files I wanted cataloged are always under My Photos. From there I create Year and Month folders so even then cataloging is more simplified for me because I can select just the Month to update. As noted above once photos are in catalog you won't be asked again.
Post by snowman1 »
I do something similar, using a folder called "Albums" ("My Photos" would probably have been a better name!).
I also use a date based folder structure under that, but I let PSU create that automatically upon ingestion so I am ensured of consistency and that the photos go in the correct folder. I ingest photos from SD cards, or in the case of photos from my phone I use PhotoSync to transfer photos to a temporary folder structure (also under "Pictures" but it could be anywhere) and then ingest from there. This also allows me to create a backup at ingest time using the PSU ingest mirror folder options.
As regards the original question, I'm not 100% sure but I suspect it may help the OP - if he hasn't already done so - to set the top level folder that PSU sees to his main picture folder, as I'm presuming PSU only scans folders below that (happy to be corrected, as I rarely if ever scan for missing images, I prefer to use the ingest function as mentioned as it gives so much more control and options).
