v2023 Flagging
Bobbert
v2023 Flagging
Post by Bobbert »
Different flags are a great addition to the "Bookmark" function in v7. Makes culling even better.
Are there keyboard shortcuts for the various flags. "B" brings up the flag options, then you can pick a flag state from a list, from 0-5, but is there a quick way to bypass the menu and directly choose the flag?
Re: v2023 Flagging
The keyboard shortcuts manual describes them as Ctrl+Alt+1 to 5
Is that what you need?
Bobbert
Re: v2023 Flagging
Post by Bobbert »
Yes - just what I needed. Couldn't find that in the pdf files in the help system.
While we're at it. I can filter for each of the flagged states separately; is there a way to filter for ANY flagged state in a folder? i.e. here are all flagged images irrespective of which type.
Thanks again
Re: v2023 Flagging
You can Alt+click on Not Bookmarked to get the inverted action
