Recently Used label update
vkfoto
Post by vkfoto »
When I'm assigning labels to an image, whether to one without any or to add to an existing set, the Recently Used set is dynamically updated as new ones are added. By itself it's not an issue but if I want to reuse several labels, I have to wait between selecting or else I run the risk of picking the wrong label since the one I want might have been moved after the update.
Don't know if this can be addressed in any way? Perhaps delay the Recently Used update until the image selection is changed?
Hesmith1029
Re: Recently Used label update
Post by Hesmith1029 »
I have seen the same issue. The recently used list moves down as more labels are added to assigned list. Move to quickly and you click on the wrong part of the screen, because things move before your click is acted upon.
