Is there a way to swap folder colors with a script?
I would like to change this now based on my experiences of the last few months. However, with so many folders individually, this is rather bad.
There are 9 folder colors with various descriptions.
I want to have the folders 5 color (yellow) and 7 color (blue) as one color.
Example:
I now want to set the folders with the 5 color (yellow) to the 7 color (blue). Then I change the description as I need it today.
greeting
Ralf
Swap folder colors via script
Ralf
(Excuse my english)
(Excuse my english)
Re: Swap folder colors via script
AFAIK There's no such script
What you can do: select multiple folders and then change the folder state. It will change for every selected folder.
Tip: Select the root and press Alt+right to recursively expand. Then select all the yellow folders (Ctrl+Click/Cmd+Click) and change them to Blue in one go.
too bad, but with the amount of folders I would be changing for a very long time. Then I leave out the colors, no matter how they are set now.
could have been
many thanks
could have been
many thanks
Ralf
(Excuse my english)
(Excuse my english)
I hope my top came across right.
1. Select multiple folders
2. Change the folder color for a selected folder
That will change the color for all selected folders in one go.
yes thanks, that came across right. Unfortunately I have more than 90000 pictures in many folders YYYY\MM\.
Going through it manually is just too time-consuming, unfortunately I used the colors to set a status that was just too confusing.
thank you for the effort
Ralf
(Excuse my english)
(Excuse my english)
