Stacks (make this the stacks top item)
germie
Post by germie »
Hi all,
Everything in the stack menu works on multiple items; when I select multiple images in stacks and select show more from this stack it opens a new tab with all members of the slected stacks.
This does not apply to "make this the stacks top item". That only works for the first selected image. Is there a way to select an image for a number of stacks and mark it as the top item at once? I have several hundreds to do :lol:
Kind regards from Holland
Germ Wind
Re: Stacks (make this the stacks top item)
Make the top item is indeed no multiple task.
But, in the preferences->cataloging->stacking you can define the stack detection rules, including how the top item should be picked. That may help here.
germie
Post by germie »
Thanks Hert,
That woukld resolve my issue.
Germ Wind
germie
Post by germie »
Just checked your suggestion and it works as described. Problem solved.
Thanks for the prompt response!
Germ Wind
