Verify Folder Binary ?
OK, has it changed ? I can't see anything relating to "binary" in the changes log ?
Re: Verify Folder Binary ?
Only the text of the menu item has changed. This used to be Verify All, now Verify Binary.
Verify Quick also verifies all, just in another way.
Verify Quick: verify based on the file stamps/size
Verify Binary: verify based on a calculated binary file signature.
The new caption better matches what it does.
Thanks Hert, I suspected it might just be the wording but thought I'd better check!
KeesdH
Post by KeesdH »
Hi Hert, can you please check the Dutch translation. For both checkes it states "Controleer map snel" which is quite confusing.
KeesdH wrote: 03 Jul 22 8:52 Hi Hert, can you please check the Dutch translation. For both checkes it states "Controleer map snel" which is quite confusing.
Thank you. I'll pass that on.
