Two bookmark related issues in V7
roddyt
Post by roddyt »
I found two bookmark-related issues with the new version, build 4268. I'm on an iMac (Intel) running Monterey.
I played with the Accent Color setting when I noticed the bookmark heart was blue instead of red, as I was used to. I changed the accent to green; everything else changed, but the heart remained blue. Then I changed it to pink, but the heart still remained blue. Then I noticed something else, the photo I was looking at is not versioned, but when I set a bookmark on a versioned photo, the heart is green, which was the first color I chose. I've attached an example of what I mean.
Screen Shot 2022-04-23 at Sat, Apr 23 4.24.45.png (593.81 KiB) Viewed 5871 times
The photo on the left was previously versioned, at which point the heart was green. I removed the versioning as a test and it changed to blue as shown. Also, should the highlighting on the label count, when 0, also use the accent color?
My second issue is with the collection filter. The bookmark "heart" filter is gone. I used that extensively to quickly toggle between all, bookmarked, and not bookmarked. I see "Bookmarked" is one of the entries in the State menu. If removing the "heart" filter was intentional, then there needs to be a "Not Bookmarked" entry added to the State menu.
Re: Two bookmark related issues in V7
I was able to reproduce the wrong colored bookmark after changing the accent color.
About filtering: you can alt+click on any state in the filter drop down to get its inverted value (Bookmarked -> Not Bookmarked or Rated -> Not Rated or ...).
Hert, should/could that apply to the Label drop down as well, so that you select Excluding (label), rather than having to select the label, then open the Filter drop down and select Invert ?
roddyt
Post by roddyt »
Good to know about alt+click for the inverted value. Perhaps you should remove the two entries "Not GEO Tagged" and "Without Areas" for consistency.
roddyt
Post by roddyt »
As an aside on the color issue, I found that after quitting and restarting, the bookmark hearts and the 0 label count background pick up the new accent color.
Shutter Bug
Post by Shutter Bug »
I agree about wishing the heart button was still there in v7. I used that extensively. Clicking or unclicking the heart is much easier than menu scroll down then Alt click.
While I'm on the subject of buttons vs menus ... I would also love to see a button for reset filter and invert filter in general instead of those being buried in a menu. I like to have the things I frequently use be buttons instead of having to select it from a menu. I know there are keyboard shortcuts but there are too many for me to remember. Even my cheat sheet of the ones I most frequently use is almost a page long. ;)
Shutter Bug
Thankyou! I see we can now Alt-Click on Labels and Type now to exclude in v4284
Sigi
Post by Sigi »
roddyt wrote: 24 Apr 22 18:56 Good to know about alt+click for the inverted value. Perhaps you should remove the two entries "Not GEO Tagged" and "Without Areas" for consistency.
Please do not remove these 2 options
apanella
Post by apanella »
Sigi wrote: 30 Apr 22 5:53
I, too, use "Not Geo Tagged" quite often.
apanella
Post by apanella »
I like the alt-click to get the inverted, Is there something that indicates the alt version is selected? (What I see is the checkmark, but that looks the same as if the value had a regular click.
The Title to the Tab page will say "selection exluding xxxxxxxxx" at the top of the page.
apanella
Post by apanella »
G8DHE wrote: 01 May 22 8:42 The Title to the Tab page will say "selection exluding xxxxxxxxx" at the top of the page.
Thx.. It was right there in front of me and I missed it
