Syntax of lr:hierarchicalSubject tag?
JeffK
Post by JeffK »
Newbie posting again here. I might have this completely wrong.
I have been experimenting with trying to put hierarchical keywords in to an images metadata keyword field.
I put in lr:hierarchicalSubject=A|B
I get literally lr:hierarchicalSubject=A as the parent and B as the child. What am I doing wrong here, or should am I doing something the app doesn't recognise at all.
Thank you, Jeff
JeffK
Re: Syntax of lr:hierarchicalSubject tag?
Post by JeffK »
OK I partly sorted this. I don't need the tag. If I write A|B I get A|B but I also get the desired result ie A as parent and B as child. (A and B can represent metadata tags.)
Why you don't use categories panel?
