Running often used scripts... via button??
Ulrich
Post by Ulrich »
Hello, everyone,
I have now written a number of (for me) very helpful scripts that relate to the selected files.
Currently I always start them via CTRL-SHIFT-X by calling the script editor and opening the required script.
This is of course possible, but it is cumbersome if you have to keep opening other scripts to start them.
Is there a possibility to link a script to a 'button', which could then be added e.g. in the info panel (similar to how you can define your own fields there)?
How do you start your frequently used scripts?
Re: Running often used scripts... via button??
Could use be made of the far left hand panel, under the burger menu space, at the moment its a big chunk of unused screen space to accomodate buttons / links :-(
Also any progress on the https://mantis.idimager.com/view.php?id=3479 which reports the uncleared active process count and progress space after running a script ?
