Few questions about labels and custom thumbmail
pattcz
Post by pattcz »
1, Next to each Catalog label is field where you can upload image and i presume when i hover over it it shows it but it just show tiny little iimage it didnt zoom in
2, As far i know you can add color to custom thumbnail info. I colored catalog labels different color so i can see it more clearly. It is possible if i assign catalog labels to different catalog labesl sets to show up in different colors ?
example i make labels (1,2,3,4) and make them as catalog label set NUMBERS and then i create labels (a, b , c ,d e, f) and make them catalog label set LETTERS
when i asign to photo label "1" and label "a" can i somehow customize custom thumbnail info to show in different colors ?
thank you for answers
Re: Few questions about labels and custom thumbmail
1) The image shows when hovered. I don't think that's tiny, but that is subjective.
2) I thought this was useful for a repository script. Here's the result and below is the way to select the Category Color Bar script.
Category Color Bar.png (31.06 KiB) Viewed 1924 times
Select Category Color Bar.png (72.64 KiB) Viewed 1924 times
pattcz
Post by pattcz »
Hert wrote: 25 Sep 21 10:50 1) The image shows when hovered. I don't think that's tiny, but that is subjective.
OK it is not tiny i just try it again, i switch PSU off and on again and it shows in full. guess it need reload.
Previous what i see.
Apparently that happens when you first drag a thumb to the Catalog Label thumb. After a restart the preview is larger.
