Not responding issue ,solved but wondering
pattcz
Post by pattcz »
Hello , today i update Photo Supreme and after it update to WiN10 come so i update it. After it, dont know what was culprit when i launch PSU it get to Not responding and even after hour nothing. So i move my catalog (154k images+videos) one folder up and force PSU created new default catalog. Then i manually open my catalog and everything looks ok. (Just some minor options like zoom level of thumbnail and Custom thumbnail reset to default)
I then try restart pc and launch PSU and mine catalog and everything looks fine.
I
So if somebody have same issue.
Close PSU.
Move your catalog elsewhere so PSU is forced to create new catalog.
Open your catalog and everything should be fine.
My catalog size was 2,4 GB and 28 GB thumb db. After compact it is now 1,9 GB and 27,9 GB.
Re: Not responding issue ,solved but wondering
I think the file movement is unneeded. Just a restart would do
pattcz
Post by pattcz »
I just move image database.thumbs.db and image database.cat.db to prevent Photo Supreme load it on startup and force it to make default catalog , i dont my images. If i dont move it Photo Supreme try load image database.cat.db and stop responding after two seconds. So when i move db files it create new default db files. Then i load manually my image database.cat.db and it works fine.
Restart of my pc or Photo Supreme dont solve it. Sorry if i describe my situation wrongly.
