Change "Main Version"
AlainB
Post by AlainB »
I use version to group together RAW, JPG and modified JPG versions of the same picture.
Sometimes the RAW version has been selected by PS as the main version. I would like to have the JPG as the main version.
Is there a way to proceed, other than destroying all (wrongly set) versions and rebuilding them again,, or doing it thumbnail by thumb nail using the GIU ?
Re: Change "Main Version"
https://repository.idimager.com/openres ... DCAD200E58
Tip; consider switching to Stacks instead of versions
AlainB
Post by AlainB »
Do you mean that the JPG version should be the Main version and the RAW version the diplay version ?
AlainB
Post by AlainB »
I have a clear case where selecting a bunch of JPG and NEF files fJPG created from the NEF, with no other files in the selection)
with custom field *.jpeg,*,jpg,*JPG,*NEF
for both "main version detection method" and "album display" gives the NEF version as main version, and not the JPG one.
AlainB
Post by AlainB »
Il was apparently a mistake to select both JPG and NEF. If I select all NEF only, the resut is correct.
