How to Copy/Paste Photos?
MikeA01730
Post by MikeA01730 »
I'm trying to transition from IDImager to Single User PSU. In IDI I could select one or more images and then copy/paste or drag them to the Windows file explorer or another application that can receive files using the clipboard. In PSU this doesn't work. If I select and copy (right-click Copy or Ctrl-C) I get a brief message "Copied x items to the clipboard" but paste in the file explorer won't work. Drag and right-click drag don't work either. Am I missing something? If this is by intent then what's the best way to select images and copy them somewhere else?
Mike
freudenthaler
Re: How to Copy/Paste Photos?
Post by freudenthaler »
Hi Mike,
there is the possibility to setup file bases sharing. You can do that with PSu's Share-functionality at the lower right menu-bar.
You can also use Alt+Drag/Drop to drag to an external application.
MikeA01730
Hert,
Alt+Drag/Drop will work! Thanks.
Mike
